agb1980 10 Posted December 12, 2014 Got a couple of issues with my alarm/ immobiliser - read lots of threads and these seems pretty common... I have a 95 vr6 with factory fitted immobiliser, issues are: 1. Occasionally car starts and cuts out after 2 seconds. The fault code i have points to the immobiliser stopping the engine start. As i understand this is the factory fit immobiliser causing this issue. Am gonna spray ignition coil connections with wd40 as recommended on here 2. Occassionally car doesn't unlock with key fob and confirmation 'beep' sounds weak. There is an aftermarket laser alarm and immobiliser fitted. I've changed battery in fob, thats about it.. Both these symptons started around the same time so just wondered if/how they are linked? Do these systems work independently of each other? Any help would be really appreciated, the auto electrician who came to look at it was unable to access the ecu with his diagnostics and his advice was "put up with it". Not very helpful! Quote Share this post Link to post Share on other sites
