Will.I.Dub
(!) Brake system warning light issue
I noticed today that my (!) light is dimly lit. It does the full brightness startup check, extinguishes to a dim glow once engine is started. Took the cap off the brake fluid resevoir to allow the float to activate it and it lights fully as it should. Any ideas why it's dimly illuminated??
  Sean_Jaymo said:
That light only works when the handbrake is on and the fluid is low as far as I can remember. Is the handbrake switch ok?
Maybe that's why mine has never lit.
