Mk3highline 10 Posted January 2, 2015 I've cracked the oil filter housing cap thing £30 from TPS the hex bolt on the bottom £15!!! Think the old one will have to do Also ordered the magnet for the cam sprocket for the sensor So might have a fully working car But the thought of having the front end off Guess the water and g12 will be changed flushed for the 4th time in 2 months More importantly I can't see gaining any more torque with it working as it should Vinc said normally one would lose 20-30bhp iirc with a cam sensor fault R32 power on a standard AUE it can't happen Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted January 6, 2015 Well all that went to pot Got the oil filter cap and came with the bolt from tps Got the bit for the cam sensor phase thing £15 As I was about to drain the water the top plastic connector between rad hose thermostat housing and small pipe to header tank broke well the small pipe snapped off Luckily I had one off the mk4 with the hose took it as a sign and left it Now the throttle body cflunked Quote Share this post Link to post Share on other sites
