kaneda 0 Posted June 14, 2004 Replacing the stock suspension with Koni TA's all round and H&R springs, I have a 95 VR6 so need the spring cups VW part No. 1H0-412-341 x 2 From GSF 45737K STRUT TOP MOUNTING KIT CO VR6 8/91 x 1 45723H BUMP STOP-REAR CO VR6 8/91 x 1 is there anything else woth replacing :?: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 14, 2004 You will obviously need 2 TM and bumpstops... Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 14, 2004 Replacing the stock suspension with Koni TA's all round and H&R springs, :?: one thing i would strongly advise is to get the geometry done a week or 2 after fitting your suspension to give it time to "bed-in"......and probably the best place to go for that....although its a bit of a drive is Star-Performance in Glenrothes..........as apart from having the same equipment as Speccy cars.....they are also a helluva lot cheaper even factoring in the fuel cost down to Glenrothes...............TBH i wouldn't trust anyone up here to do it...other than Speccy-cars but IIRC they charge over £100+vat for it whereas Star-Performance are only £40+vat :wink: Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted June 14, 2004 If you're fitting these yourself, remeber to trim one segment out of the front and rear bumpstops or the ride will be somewhat firmer than you expected... Quote Share this post Link to post Share on other sites
kaneda 0 Posted June 14, 2004 I will prolly do that, Glenrothes isn't to far, cheers Quote Share this post Link to post Share on other sites
