Wayne2015 10 Posted April 10, 2015 no m8 they are just normal H4 bulbs think they are filled with xenon gas i do know that since fitting them i often get flashed by others coming towards me at night as if i was on full beam. sometimes i give them a taste of what full beam is if they are overzealous lol for example http://www.mecatechnic.com/COR_UA17014_GB_2-ring-xenon-ultima-h4-bulbs-vw-corrado.htm Lol (ref full beam) I know what u mean, these days u simply cannot tell if one have full beam or just very bright lights ... Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted April 10, 2015 Lol (ref full beam) I know what u mean, these days u simply cannot tell if one have full beam or just very bright lights ... indeed! with my VR being lowered when these fancy chelsea tractors & their HID's are behind me they end up blinding me in all 3 mirrors Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 (edited) As one front high beam bulb blown One fog bulb blown Got some clear side indicators to fit Want to place nice amber film on fog lights Apart from upgraded headlight loom... What bulbs/LED good for all the front/side lights??? I am thinking OSRAM Nightbreakers for main beams - not sure of the others? Manual does not specify type of side bulbs :( Thanks! Ok I have rushed and bought these now: Main beam: High beam: Fogs (+ amber film) Still unsure what bulbs for: 1. Side indicators are 2. Front turn indicators 3. No.19 in pic below are? Have also bought replacement wing mirror glass, as mine are severely corroded from the edges, and the driver mirror is very poor coverage to almost dangerous! :eek: Will research to how to fit ... Edited April 14, 2015 by Wayne2015 Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 indeed! with my VR being lowered when these fancy chelsea tractors & their HID's are behind me they end up blinding me in all 3 mirrors Get one of these? Or go retro Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted April 10, 2015 ha ha i like it wayne!! normally i just give one of these... ;) Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 ha ha i like it wayne!! normally i just give one of these... ;) :lol: Or one of these ... Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 As not used driving classic cars as daily or over 6000miles a year, my honda was low on oil and had to top it up quickly! :eek: My topping up skills :eek: As I drive my C more and more, do not want panic 230miles away from home and panic buy then top up oil WITHOUT a funnel like last week :shocked!: So will the same oil for my 1989 Honda ok for my VR6? Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted April 10, 2015 Just noticed my front side lights comes on slowly ...dim to bright. Is that normal? Is it the bulb? Sounds normal if the "dim-dip" is functioning correctly. There is a low voltage put through the dip beam bulbs when using side lights, which reacts slowly. If you fit an updated loom, you will bypass/disable that feature. Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 Sounds normal if the "dim-dip" is functioning correctly. There is a low voltage put through the dip beam bulbs when using side lights, which reacts slowly. If you fit an updated loom, you will bypass/disable that feature. Cool :D Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted April 10, 2015 Ok - can u see the light switch illuminated here? Nor can i :( Is it supposed to be illuminated? It should illuminate when the ignition is on (so you can see it to switch your lights on when it is dark - not much point showing you where it is once you've found it to put them on) . The window switches etc will also illuminate at the same time. Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 It should illuminate when the ignition is on (so you can see it to switch your lights on when it is dark - not much point showing you where it is once you've found it to put them on) . The window switches etc will also illuminate at the same time. Mine dont illuminate :( Is there a bulb behind it? So just prise off switch and replace bulb? Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted April 10, 2015 Mine dont illuminate :( Is there a bulb behind it? So just prise off switch and replace bulb? No idea mate, never take it out. I can check later if no-one else knows before then. Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 No idea mate, never take it out. I can check later if no-one else knows before then. If u got time, mate! Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 Going to have to decide soon if broken sunroof worth replacing with a passat moonroof at some point ... Dont fancy driving in motorway in this hot weather with - no sunroof no air con Sweaty hands and high blood pressure dosent help neither ! :eek: :shocked!: Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 10, 2015 Going to have to decide soon if broken sunroof worth replacing with a passat moonroof at some point ... You'll only break it by looking at it ;) Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 You'll only break it by looking at it ;) No i did not break your spare sunroof last night! :lol: Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 10, 2015 No i did not break your spare sunroof last night! :lol: Not completely, but your good luck finished it off, lol. Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 Not completely, but your good luck finished it off, lol. I fear for all on this forum that HAD and might HAVE contact with me :eek: Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted April 10, 2015 Hopefully that's not virtual contact lol Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted April 10, 2015 Although I do have a water leak although think it's just a hose Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 Although I do have a water leak although think it's just a hose Hope u get it fixed though .... Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted April 10, 2015 Oh I will and will report back.... How was your Easter trip to Bristol.... Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 Oh I will and will report back.... How was your Easter trip to Bristol.... Would have been nicer cruising in the C for 230 mostly motorway miles ... Then again my Honda sunroof works - the C one dosent :( Spot the famous landmark in the back! And u ever seen this much food (buffet as well) for lunch for a mere £8.99??? YUM YUM :dance: Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted April 10, 2015 If u got time, mate! Looks like the bulb is a similar setup to the fog and rear screen switches, with hard wired bulbs. Nothing accessible without dismantling the switch. I've changed the bulb in my rear screen switch, so doable enough. [ATTACH]81295[/ATTACH] Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 10, 2015 Looks like the bulb is a similar setup to the fog and rear screen switches, with hard wired bulbs. Nothing accessible without dismantling the switch. I've changed the bulb in my rear screen switch, so doable enough. [ATTACH]81295[/ATTACH] Cheers Tiger! :thumb right: I ll leave mine as is for now then ... Quote Share this post Link to post Share on other sites
