GlosterOx
Bonnet Pins/Springs
Fitted some refurbisherd ones yesterday, a quick 10 minute job, but then spent probably another 30 minutes or so getting everything properly aligned and to the correct height. I now have a bonnet that opens and shuts fine, but there is a metallic "noise" from the passenger side one now everytime I close the bonnet?
What I noticed on the ones I removed was that one piece of the bottom plastic/nylon(?) was reversed by 180degrees compared to the other, and I can't think why even though they worked perfectly. Below is a pic of how I have them now, both the same way around, but can somebody check on theirs and see if this is correct or should one (N/S?) be reversed?
Ian.
Edited by GlosterOx
Where did you get those mate , sorry i cant help with the problem though
Bought them 2nd hand and got them replated at work, really pleased with how they came out!
Ian.
