MZpog
Passat Sunroof/Moonroof swap seems slow - Grease???
Did a swap of my tilt only sunroof for a Passat moon roof and must say I like it lots.
The swap required me to use my old motor (4 pin plug) rather than the Passat motor (6 pin plug) and whilst it works fine it seems a little slow when closing the slide.
Is there a way to rewire the 6 pin motor to 4 pin to see if this is any quicker? If not what sort of grease/lube should I use on the runners?
VW do a specific, very expensive grease for the sunroof. By all accounts it is the only thing to use in the long term as it resists oxidation and hardening, and contamination with dirt.
Best wishes
RB
Best wishes
RB
that they do Rog BUT there is also a very good alternative via ebay for £7
http://www.ebay.co.uk/itm/Liqui-Moly-Silicone-Grease-100g-3312-/221336236084
i got some on recommendation from Kev Beercan a while back ;)
Just read this thread and thought to keep my sunroof working its work me greasing it - its still the original roof - found the part number for the VW grease -G-000-450-02 although I cant find it on line anywhere in the UK - not tried VW yet (last resort) - do any other greases work - I have read NOT to use Lithium.
Would a silicone based grease be OK? A si know plumbers use this and I have heard it being used on cars and its defo cheaper that I believe the VW stuff is?
Thanks
happy to help :)
FYI i have also used it on the tops of my door rubbers when the weather is very cold - it helps stop the doors freezing shut
