Gwr vr6
Door handle loose
Passenger door handle has went loose on my car . Is there a sliding are on the back that should hold it in place if so it's been pulled out of place . Is this an easy repair . Thanks for any help
Check the trailing edge of the door and you should see a cross head screw just above the door latch mechanism. Make sure that it is tight, it locks the handle into place.
Check out the photo below. You need to tighten the black screw which is just above and to the left of the door latch on the back of the door. It passes through the door and screws into the door handle. If it is loose or missing, the handle will be loose. If you need to tighten the one on the drivers door you will find that it has a left hand thread and needs to be turned anti-clockwise to tighten it.
Cheers for the help lads . Top job cheers leon that's exactly what it was . I was thinking I'd be having to take the door card off and be messing about for an hour or so . Thanks again
