dazzyvr6
electrical problem
right,my central locking now only works when using the key,it used to be total closure but after a blown window fuse it hasnt worked proporly since..the windows used to go up as soon as i turned the ignition off,even if i turned the ignition back on they would still go up,but ive cured this by dissconnecting a block on the window control module,ive dissconnected the alarm completely to see if it was causing the windows to go up,but no difference,so that rules out a fault with the alarm,so anyone with any ideas as im going nuts...i keep leaving the car open as i forget the central locking isnt working on the alarm fob
