Riclad
Changing the dipped bulb!
I have just tried to change my dipped light bulb, i gathered i had to take the headlight out as the radiator casing is in the way, HOW DO YOU GET THE BLEEDIN THING OUT? I took the 3 clips off and took the screws out . . . . . . . .no good. I cant do it. Call me stupid i know. Help please!
Cheers, Rich.
How many screws did you remove? There's 3 per light. Did you find the 3rd ones OK?
Once all the screws are out, it's just a case of easing it out.
K
Ahhh, That might be it. I only took 2 screws out which were on top. Where's the 3rd one then buddy?
Cheers, Rich.
there's a hole in the slam panel halfway along the lamp about an inch and a half from the front... it's down there... ;) :D
