MZpog 10 Posted April 12, 2015 Had a few hours spannering due 2 captive nuts spinning and managed to remove and clean out the spoiler mechanism and motor and its now silky smooth. Made sure the microswitches were parking/working correctly then bolted it back in. Test drive to see if the automatic function works and alas, still switch only. I will now swap out the spoiler control unit for one of my other 2 spares and whilst I have no idea if any work, surely I can't have 3 duff. If the swap out doesn't work I have no idea what it could be. Someone did mention something about a resistor or sommat in the clocks that goes duff and any link to this may be needed/appreciated. Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 12, 2015 Nice one Stuart :) Unfortunate its still not working :( Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 12, 2015 A few useful threads? http://the-corrado.net/showthread.php?t=80014 http://the-corrado.net/showthread.php?t=74229 Not useful to u, but really nice diagrams ;) http://the-corrado.net/showthread.php?t=17303 http://the-corrado.net/showthread.php?t=49013 Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 12, 2015 More http://www.corrado-club.ca/forum/viewtopic.php?t=12740 http://www.corrado-club.ca/forum/viewtopic.php?t=14509 http://www.corrado-club.ca/forum/viewtopic.php?t=14916 Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 12, 2015 More http://www.corrado-club.ca/forum/viewtopic.php?t=12740 http://www.corrado-club.ca/forum/viewtopic.php?t=14509 http://www.corrado-club.ca/forum/viewtopic.php?t=14916 Seen em all, but thanks. Also found the info on the transistor that fails in the 2.0 clocks so that may be the problem. Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 12, 2015 Seen em all, but thanks. Also found the info on the transistor that fails in the 2.0 clocks so that may be the problem. :thumb right: Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 13, 2015 Have you metered the wire from the VSS to the spoiler module? Pin 8 0n the module. Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 13, 2015 Have you metered the wire from the VSS to the spoiler module? Pin 8 0n the module. Yes, checked when I had the fuse box out to fit the heated seats. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 13, 2015 So does the wire from Pin 8 on the module go the VSS on top of the gearbox, or the wiring loom on the instrument cluster? Also what colour is the wire on Pin8 The reason I ask is I am myself a bit confused looking at the diagram to where it goes. But hopefully we can work through it. Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 13, 2015 So does the wire from Pin 8 on the module go the VSS on top of the gearbox, or the wiring loom on the instrument cluster? Also what colour is the wire on Pin8 The reason I ask is I am myself a bit confused looking at the diagram to where it goes. But hopefully we can work through it. I think the wire tested was white/blue and I only checked that it had continuity to the multiplug on the top of the fuse box. My understanding it the VSS goes to the clocks, then out to the multiplug - I may be wrong however. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 13, 2015 What year is your motor, and is mileage counter digital? Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 13, 2015 2.0, 1992 and the mileage is digital. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 13, 2015 Okay, this how i think it works according to the diagram. VSS --> Fusebox G1/11 Fusebox G1/11 -->Fusebox U2/2 Fusebox U2/2 --> Dash loom T28/21 Dash loom T28/27 --> Fusebox U1/11 Fusebox W/1 --> T43? T43? --> Module This is how it should trace out, just not sure what T43 is. It's some kind of terminal, I've got cable tracer at home that you could borrow. Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 13, 2015 Okay, this how i think it works according to the diagram. VSS --> Fusebox G1/11 Fusebox G1/11 -->Fusebox U2/2 Fusebox U2/2 --> Dash loom T28/21 Dash loom T28/27 --> Fusebox U1/11 Fusebox W/1 --> T43? T43? --> Module This is how it should trace out, just not sure what T43 is. It's some kind of terminal, I've got cable tracer at home that you could borrow. Now I'm lost with T43 too and no mention of it on here http://www.a2resource.com/electrical/CE2.html Speedo works so I assume the problem (if wiring) is somewhere further down the chain. Cable tracer? I have a few multimeters but is this something else? Gonna change my spoiler module tonight for one of my spares to see if anything changes. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 13, 2015 Yeah try the module, but also trace the wire from the module pin8 to the fusebox W/1. If you have continuity I guess you have T43 fitted. Or see if you can find where that wire goes form the module, post a picture of it if you find it. Cable tracer, you attach one wire to a toner that your looking for. Then wave a wand around the wiring looms to try and follow where it goes, so that you can find the other end. Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 13, 2015 Yeah try the module, but also trace the wire from the module pin8 to the fusebox W/1. If you have continuity I guess you have T43 fitted. Or see if you can find where that wire goes form the module, post a picture of it if you find it. Cable tracer, you attach one wire to a toner that your looking for. Then wave a wand around the wiring looms to try and follow where it goes, so that you can find the other end. Will have another go at the pin 8 to W1. I'm sure I tested continuity from pin 8 to multi connector with the blue/white wire connector, not W1. Cable tracer - I have 2 lol. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 13, 2015 Not sure which multi connector you mean Can you check if you continuity from the module pin8 to VSS on the gear box. Might be quicker and easier to do first. With everything plugged in as it should be Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 13, 2015 (edited) Not sure which multi connector you mean Can you check if you continuity from the module pin8 to VSS on the gear box. Might be quicker and easier to do first. Saves pulling the fuse box out too. Multi connector at top left of fuse box (when looking from behind) - has 4 x blue connectors plugged in next to each other....like this http://www.3dzubehor.com/B4/9vt12k1x3qwul2c3how.jpg Edited April 13, 2015 by MZpog Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 14, 2015 Can you check if you continuity from the module pin8 to VSS on the gear box Actually that might not work, as don't know what the circuit is like in the dash board. So check continuity from Dash loom T28/27 --> to the module. If you don't want to drop the fuse box just yet. Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 14, 2015 Actually that might not work, as don't know what the circuit is like in the dash board. So check continuity from Dash loom T28/27 --> to the module. If you don't want to drop the fuse box just yet. Might have a go at this tonight when I swap out my clocks to see if that fixes. If it does then transistor required for original clocks so I can keep the mileage correct.....not that it is correct having been rebuilt 50k miles ago. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 14, 2015 Worry about the correct mileage later :-) Lets try and get to the bottom of your spoiler issues. Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted April 14, 2015 Did it work correctly before you stripped and cleaned it? Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 14, 2015 Did it work correctly before you stripped and cleaned it? Worked on switch but seemed to pause/stick so stripped/cleaned and now its smooth. It's never worked automatically for me :( Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 15, 2015 Ok so last night I swapped out my clocks for an ebay set. Mileage is give/take 2k more than mine but I did hope the change would fix the spoiler. Anyway a test drive to the shops, 45mph seen and no movement. This morning however 60mph seen and up she goes, OMG I have the VR spec module fitted :) :) :) speed drops to slow and down she goes.....how the hell I'm not gonna crash when watching this I'll never know. Now to order a replacement transistor (the bit that allegedly fails) for my old clocks and fix them. Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 15, 2015 Yee-haa :dance: Well done, Stuart! :thumb right: Hard work and determination does pay :) Now u just have to watch front too as I pull away from u! :) :lol: Quote Share this post Link to post Share on other sites
