edition
VR6 Breather pipe
Hi,
I've just put a vr into my mk2 golf and have a question about the pope that goes from under the left hand side under of the throttle body onto the little black valve and then onto what I beleve should be the carbon canister....
Do I need this pipe or can I just block it off? The little elbow on the pipe has broken off and I'm not running the carbon canister.......
Thanks in advance.
Are you on about the pcv valve mate? Little plastic circular looking thing. If so and the pipe is split I think you can expect a rough starting and bit of a lumpy idle.
