Grrrrallye
Cable runs
I'm just about to start my stereo install this week.
I have had a quick look but was wondering where people have broken through from the engine bay into the car for power cables etc?
My intention is to locate the amp in the wheel well with a false floor so was going to run along the center tunnel to the rear of the car. Any advice?
With the speaker cable runs, I understand that the C speaker feeds run from the head unit up to the tweeters, then to the doors. My intention is to mount my crossovers under the glovebox and the fuse board. I want to use the existing cables to tow in new cables from the crossovers. Are the existing cables loomed or can i use them to tow?
Thanks
Alex
I had a hole in the bulkhead with a rubber grommet in it underneath the water bottle and just to the right of the ABS stuff in my VR. It comes out behind the lower trim on the passenger side and is easy enough to run from there. I tried to take a pic but it's all wet and rainy lol
There are some holes on the passenger side, if you take out glove box, the shelf below and pull the carpet back, the abs loom goes through there.
