Dan1987 10 Posted May 18, 2015 (edited) Hi all just bought a real clean Corrado 16v never had one before but had many mk2 golfs etc The car looks great but in having some running issues It's running very rich There's nothing there at all unless you plant your fit and let revs build pulls after about 3k Lumpy and rough running and idle unless foot planted Any ideas Thanks Edited May 18, 2015 by Dan1987 Quote Share this post Link to post Share on other sites
Dan1987 10 Posted May 18, 2015 Best I can describe it is on idle its like been in the pits at drag racing with the v8s chugging that's how its running and sounds at idle Quote Share this post Link to post Share on other sites
Pipkin 10 Posted May 19, 2015 Mine is doing the same, gunna clean the icv one evening and see if that makes it better, i did a run down to apex festival in kent last weekend and averaged 21.9mpg at 60-65mph! Hurt the wallet a bit lol Quote Share this post Link to post Share on other sites
easypops 8 Posted May 19, 2015 Fifth injector can over fuel it, throttle potentiometer possibly, idle control valve, the 2 very small hoses that run from throttle body rubber to air box area (I think, it's been a while). Running/idling issues on the 2.0 16v have been discussed a lot over the years, the search is your friend:) Here you go for a wee start http://the-corrado.net/showthread.php?t=35823&highlight=Kangaroo Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 19, 2015 Sounds like the timing is out... Quote Share this post Link to post Share on other sites
Dan1987 10 Posted May 19, 2015 The car seems to idle fine and drive ok for first few mins from cold like while on auto choke ? , and how can I be sure on timing Quote Share this post Link to post Share on other sites
Jim 2 Posted May 19, 2015 Hmm... that sounds like it could be the lambda probe? Is it a 1.8 or 2.0 16v? Quote Share this post Link to post Share on other sites
Dan1987 10 Posted May 19, 2015 Previous owner advised kr top 9a bottom so 2.0 is guess pics to follow this evening Quote Share this post Link to post Share on other sites
easypops 8 Posted May 19, 2015 Is the 5th injector plug plugged in? If faulty it can keep fueling, mine was unplugged on my old valver for that reason and it never caused any problems leaving it like that Quote Share this post Link to post Share on other sites
Dan1987 10 Posted May 19, 2015 Ok so 5th injector is plugged in and unplugging that or the icv whilst running makes no differance at all Quote Share this post Link to post Share on other sites
Dan1987 10 Posted May 19, 2015 How do I get photos from my iphone 4 onto here ? Quote Share this post Link to post Share on other sites
easypops 8 Posted May 19, 2015 Best to use a photo site like photobucket, you can upload them to there then that gives you the option of a few links to the picture. You choose the last link and copy and paste it in and the photo appears, that's what I do anyway. There is a way to do it using the forum but you'd need to resize your images first Quote Share this post Link to post Share on other sites
Dan1987 10 Posted May 20, 2015 [ATTACH]81572[/ATTACH] Quote Share this post Link to post Share on other sites
Dan1987 10 Posted May 20, 2015 That's my engine peeps please helpe get her running ha Quote Share this post Link to post Share on other sites
Dan1987 10 Posted May 20, 2015 Right found grey plug side of airbox and can't see a lambda ?? It has a 421 Quote Share this post Link to post Share on other sites
