Madjackal 0 Posted June 4, 2015 My aux belt has started turning into spaghetti and have ordered a new one from VW. Golf VR belt (aircon version). Does anyone have any advice, how to's and or pictures for fitting this please? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted June 4, 2015 if it is the belt i think you are referring to there is a screw hole into which you can put a bolt, this then releases the tensioner so as you can remove & refit the belt & then remove the bolt Quote Share this post Link to post Share on other sites
Madjackal 0 Posted June 4, 2015 I was referring more to running the belt to make sure it hits all the pulleys etc. But cheers for the bolt info! Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted June 4, 2015 I was referring more to running the belt to make sure it hits all the pulleys etc. But cheers for the bolt info! ahh I see ok, no probs Quote Share this post Link to post Share on other sites
Madjackal 0 Posted June 7, 2015 I coul really use some help on this if any one cam provide some instruction. Really need to get my car on the road. Quote Share this post Link to post Share on other sites
borachris 0 Posted June 7, 2015 It's pretty much a case of just putting it back on the same way. Take pictures or draw a diagram of the route before you remove the old belt, Quote Share this post Link to post Share on other sites
Madjackal 0 Posted June 7, 2015 cheers. I am all donr except bolting the charger back on, even with the tensioner fully undone i can get the bolts to line up? Any help! Quote Share this post Link to post Share on other sites
