Madjackal
Supercharged VR6 Auxiliary Belt
My aux belt has started turning into spaghetti and have ordered a new one from VW. Golf VR belt (aircon version).
Does anyone have any advice, how to's and or pictures for fitting this please?
if it is the belt i think you are referring to there is a screw hole into which you can put a bolt, this then releases the tensioner so as you can remove & refit the belt & then remove the bolt
I was referring more to running the belt to make sure it hits all the pulleys etc. But cheers for the bolt info!
ahh I see ok, no probs
I coul really use some help on this if any one cam provide some instruction. Really need to get my car on the road.
It's pretty much a case of just putting it back on the same way. Take pictures or draw a diagram of the route before you remove the old belt,
cheers. I am all donr except bolting the charger back on, even with the tensioner fully undone i can get the bolts to line up? Any help!
