aks_uk
Electric Mirror question
Hi, heres the situation. I have an early type Corrado with late door cards. The electric mirror plug does not fit into the switch (ie the plug is flat shaped compared to the late type). Does anybody know how I could wire up my mirrors? which wire goes to which terminal on the switch? If I can't do this then I may have to cut a hole on the door card and fit the big ugly (in my opinion) early switch which I don't want to have to do
Thanx.
I also have late door cards in an early car but can't remember it's done. I helped out bigpants baby with the same problem a few months back, he might still have the PM's I sent on his computer. If you send him a PM, he might be able to forward them to you or indeed tell you straight up as he has only done this recently. Hope this helps mate, it can be done! 8)
