robrado974 1 Posted July 5, 2015 I'm currently collecting parts for my underside refurb . The fuel filter housing (bracket) , on the 92VR is metal , mine is a rusty mess . I went to see a mate today who is breaking a 94 Vr and got some parts off him , I wanted the filter bracket so u could clean it up and paint it , to save taking mine off , until it comes to fitting . It was only when I got under the car I saw it was a plastic holder , much better than a metal one and just a clean up and it will be ready to fit . But the holes for the studs are offset , the metal one is inline . Would it matter if the bracket was at an angle ? As long as the pipes are not kinked and I can manage to get it to fit I don't think it would be a problem . Or , if only one nut was tight and the other end not attached , would this be a problem ? There's no weight to a filter , so it's not like it would be a strain on the bracket . Has anyone tried to fit a plastic bracket to an early car ? . Any thoughts are appreciated . Rob Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 5, 2015 Mine is plastic and when i was under car i noticed i have 4 studs on the floor for the filter housing. Thought it was odd as two look welded on. I wonder if some one in the past has fitted two more for the reason you say. I never knew there was a metal housing. Should be fine fitted at an angle the pipes are flexible where they enter as exit the filter Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 5, 2015 I wouldn't go with just one nut to hold it on. I could see it moving up and down and over time might cause an issue Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 6, 2015 Thanks Jim , I thought it would be ok to fit . That's strange , that you have four studs . RE the metal brackets , they must have fitted to early cars and swopped in 93 . I didn't know they did a plastic bracket . Quote Share this post Link to post Share on other sites
delfinis38 1 Posted July 6, 2015 (edited) Thanks Jim , I thought it would be ok to fit . That's strange , that you have four studs . RE the metal brackets , they must have fitted to early cars and swopped in 93 . I didn't know they did a plastic bracket . my plastic bracket is held up at both ends with panel clips / captive U nut / Speed Clips.... similar to these in this link, then a nut over the stud, stops any movement even before a nut is attached. http://www.ebay.co.uk/itm/like/391177530859?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&rlsatarget=&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F710-134428-41853-0%252F2%253Fipn%253Dicep%2526icep_id%253D67%2526mtid%253D1673%2526kwid%253D1%2526crlp%253D50600204586_563391%2526icep_item_id%253D391177530859%2526itemid%253D391177530859%2526icep_meta_categ_id%253D131090%2526icep_etrs%253DY%2526icep_epid%253D-999%2526icep_ctlg%253D-999%2526icep_cond%253DNew%2526targetid%253D75951454746%2526rlsatarget%253D%2526rpc%253D0.20%2526rpc_upld_id%253D51874%2526device%253Dc%2526icep_msku_flag%253Dn%2526icep_cbt%253Dn%2526adtype%253Dpla%2526gclid%253DCJWq-MzvxcYCFQ3HtAodA48H2A%2526srcrot%253D710-134428-41853-0%2526rvr_id%253D862029871577 I bought some from VW recently about 50p each, guess most cars are not original theses days so don't have them. may be able to find a part number if you require it. Edited July 6, 2015 by delfinis38 Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 6, 2015 Thanks mate , that's very helpful indeed . Rob Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 6, 2015 I binned those little clips on mine, they were so rusty and forgot to order new ones, plus they made it a git to get the filter off. I just used some washers. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted July 6, 2015 VWHT 002 257 Bought some a few months back 51p each you need two... I bought a load for stock. Jim what's rust, never any of that. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 6, 2015 VWHT 002 257 Bought some a few months back 51p each you need two... I bought a load for stock. Jim what's rust, never any of that. Rust is a weight saving feature, its between steel and carbon fibre. Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 6, 2015 Thanks for the part no , much appreciated . Quote Share this post Link to post Share on other sites
