Finch
Clutch problems
Having an issue with my clutch sticking down only seems to stick down when crawling in 1st gear but if I pull it back up its fine doesn't stick any other time don't slip or have any other issues any ideas
possible slave or master cylinder at fault, you can disconnect the clutch Master cylinder at the pedal with a flat screwdriver by removing the clip to see how free the pedal itself actually moves, i just replaced my M/C for the same reason, pics in my thread,members gallery last page if interested
Going to check the return spring first if it's not then going to try the fluid but reading vw_owner_85 thread think it's same problem so looks like master cylinder :( but will keep you posted thanks for the help guys
