VR-OOM 0 Posted July 31, 2015 Looking for advice on wheels that will fit a VR and clear Brembo 4 pots with 323 discs. Any advice welcomed. Cheers James Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted July 31, 2015 http://the-corrado.net/showthread.php?76008-What-wheels-will-fit-Brembo-4-pot-305mm-discs-of-ibiza Quote Share this post Link to post Share on other sites
Jamie 1 Posted July 31, 2015 VR-OOM said: Looking for advice on wheels that will fit a VR and clear Brembo 4 pots with 323 discs. Any advice welcomed. Cheers James I can't help you with your actual question James but I can tell you I had loads of grief getting my 17" RH ZW1s over 312mm with Brembos. Even now clearance is really tight Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted July 31, 2015 OZ super T Team Dynamics (unsure of model but they look the same) Compo MO5 Compo TH1 or TH2 I have 330mm discs and 4 pots under Super Ts Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted July 31, 2015 also, I have some 323mm discs going cheap if you want them? Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted August 3, 2015 Cheers VAG, I'm presuming you're refering to the Superturismo? What size are your running 17x8? and what ET? Cheers James VAG-hag said: OZ super T Team Dynamics (unsure of model but they look the same) Compo MO5 Compo TH1 or TH2 I have 330mm discs and 4 pots under Super Ts Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted August 3, 2015 Hi James, Yes Superturismo 8x17 et is 33 i think, ill check next time they are off the car Quote Share this post Link to post Share on other sites
mic_VR 3 Posted August 3, 2015 Rota Force's (17x8J ET35) and BBS CH's (17x8.5J ET35) both clear my AP 4pots Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted August 3, 2015 mic_VR said: Rota Force's (17x8J ET35) and BBS CH's (17x8.5J ET35) both clear my AP 4pots Thanks Mic, I'd looked at the Rota's and wondered whether they'd fit :-) Quote Share this post Link to post Share on other sites
davevw 0 Posted August 3, 2015 Bbs ch 006 clear boxster s front calipers with 8-10 mm spacer Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted August 7, 2015 BILLCOR said: http://the-corrado.net/showthread.php?76008-What-wheels-will-fit-Brembo-4-pot-305mm-discs-of-ibiza Thanks for the link, I saw you ran the Ultraleggera's over Brembos, any issues? Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted June 6, 2016 Went and bit the bullet and bought a set of 17x8 OZ Ultraleggera's, really happy and good clearance over the Brembo 323's Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 7, 2016 Maybe a bit late James but I have Kev's old RH ZW1's I need to sell if interested? Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted June 7, 2016 Bigger bit late now :-( Quote Share this post Link to post Share on other sites
