robrado974
Removing windows question
I've read in the search that the scrapper has to be removed in order to get the window out . Is there any way if doing this without removing it ? . I have a rattle coming from the glass hitting the metal guide that runs up the 'b' pillar . There is a plastic part that is stuck to the glass , this then sits in the metal guide . When you bang the door this is vibrating on the glass . I need to get something behind it to stop the two making contact . I don't want to remove the scraper , they are brand new , if it bends I will cry ! .
Any info is appreciated
Rob
