Storm
Centre consol removal
Please can someone tell me how to get the centre consol out? The bit behind the the gearselecter bit. Oh and the trim on the handbrake?
remove handbrake sleeve by releasing the clip underneath. slide the handbrake handle and lever right off.
remove the screw under the handbrake
pull out the ashtray, I think there's a screw under ther too, poiting forwards. lift out the centre arm rest and unbolt that too.
you should be able to lift off the reear section now.
to get the front scetion off loosen the 4 platic plugs, 2 either side of the tunnel and lift it up. then slide it forwards over the handbrake.
Cheers fellas done, I now have 5 speed shifter, leather boot etc installed. The auto wiring removed and three pedals.
