daves16v 1 Posted August 23, 2015 Corrado VR6 Black 1994 Well the time has come to part with my Corrado and move onto other things. I've owned the car since 27/03/2010 and have carried out extensive work during that time, all receipts have mileage and dates, below is the full spec. Most of the work carried out is detailed in my members gallery here - http://the-corrado.net/showthread.php?48656-Black-Metallic-VR-Inlet-Temp-Sensor-Upgrade There is a huge pile of receipts from my ownership and more from previous owners. The car is always kept in a heated garage. 1994M Corrado VR6 Brilliant Black Metallic LA9V First registered 08/08/94 180710 miles on the car 130k miles on replacement engine (fitted at 179035 miles on 08/04/14) MOT expires - 19/07/16 BBS RC alloys 7.5x16" with polished centre caps and locking wheel bolts Bastuck 2.5? exhaust with round tailpipe complete with Stainless Steel rear box hanger Cobra Full Closure Alarm Glass Sunroof Black Heated Leather Interior with Stainless Tilt Handles OBD2 Conversion Smoked Rear Lights New Parts During My Ownership: Schimmel 263 Cams INA Tappets Replacement Timing Chains and Tensioners VAG complete clutch, bearing and lever arm Clutch Master and Slave Cylinders VAG thermostat and housing/seals Bilstein B12 Suspension Kit VAG Front Top Mounts and Bearings Golf 02J Shifter Stainless Gear Surround NGK spark plugs Sump fitted with baffles and powder coated Sump Gasket Injectors Refurbed ARB Links Serpentine Belt All coolant senders Radiator sender Coolant Radiator Coolant Fan mounting powdercoated with Stainless fixings Front Suspension Ball Joints Replacement washer piping VDO oil pressure sender VDO Gauges Fuel Filter Water Pump Ignition Switch Golf Mk4 Header Tank Golf R32 Rear Wishbone mounts Wishbones Powdercoated Rear suspension beam powdercoated and fitted with new axle bushes Rear discs, pads and wheel bearings VAG Coilpack Goodridge rear braided hoses 288mm front calipers recently refurbed with new seals and powdercoated Front Stainless braided hoses Golf Mk4 rear calipers Lupo Aero Wipers Battery Oil Temp Gauge Sender VAG floor mats VAG Crackpipe VAG Aux water pump Front and rear seat guides VAG oil cooler seals VAG door pins Beru spark plug leads Smoked side repeaters Stainless tailgate strut screws Tinted headlight reflectors Centre tunnel fixing bracket Uprated door handle striker arms Rear wiper removed Rear towing eye removed Golf Mk4 Leather handbrake The Engine Bay has undergone extensive custom modifications as detailed below - All plastic engine covers removed SWG Single Piece Scuttle Panel Part powdercoated and polished cam cover Powdercoated inlet manifold Polished throttle body Custom designed Polished Stainless Steel HT lead holders Polished belt tensioner Polished Stainless Steel radiator elbow Carbonio Induction Kit with Polished Stainless Steel mounting Stainless Steel custom made header tank bracket Stainless Steel custom made vac pipe bracket Stainless Steel bonnet prop Uprated headlight loom with Stainless relay enclosure Various Stainless underbonnet screws Stainless radiator brackets Various Polished Stainless Hose Clamps Trimsport Polished Alloy Oil Filler Cap Bonnet insulation removed and polished There are numerous other polished Stainless Steel brackets in the engine bay too many to mention. It really needs to be seen! Bad Points: Rear tyres are nearing their limit. There is no Stereo but the engine makes up for that! There has been some panel repaint done by a previous owner that doesn't quite match other panels. Stonechipped bonnet There are some parking dents but nothing major. Some minor wear to the driver seat bolster but nothing major. List Date: 8/23/2015 Location: Nottinghamshire, United Kingdom For more info, click here to view the original listing: Corrado VR6 Black 1994 -------------------------------------- SOLD -------------------------------------- Mobile friendly version: Corrado VR6 Black 1994 Go Mobile: Download the free Panjo iOS app now! Quote Share this post Link to post Share on other sites
