Ben Hunt
20vt converted G60 - Engine temp and rev gauge not setup...
Hi all,
My new corrado g60 has a 1.8 20vt installed and the original engine temp needle and rev gauge aren't set up. Can anyone give me an idea what would be needed to make these work as i'm guessing its not just a plug them in situation... Otherwise the previous owner would have.
Thanks in advance :)
Ben
what management you using?
With OEM and some of the aftermarket ECU's you can instal a later cluster without the speedo cable and the tacho will work.
The engine temp will need a resistor inline with the sensor, cant remember the value of the top of my head, will look tomorrow if no one else lets you know
