delfinis38 1 Posted September 20, 2015 Where's the best place to purchase one from... I guess I'm after the late type think it's rubber as opposed to paper.... Any advice for fitting... Any gasket sealer needed or just clean mating surfaces. Is there a sequence to tighten bolts and what torque. Ta... Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted September 20, 2015 unsure on best price wise but I bought mine from AVS (was the rubber type) Quote Share this post Link to post Share on other sites
Fine wine, Belgian chocs. 1 Posted September 20, 2015 It sounds daft but I got mine recently from Amazon... http://www.amazon.co.uk/gp/product/B0068MSCKE?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00 It's the rubbery one not the card/cork/cr@p one. I tried ordering from Euro Car Parts but gave up after getting two wrong ones. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted September 22, 2015 afternoon bump.... gasket sealant or dry..... torque settings... Quote Share this post Link to post Share on other sites
science 0 Posted September 22, 2015 Use either sealant or a gasket not both. I hate using sealant as the mating surfaces need to be spotless and perfectly flat and I don't like the thought of loose or excess sealant blocking oil ways. Quote Share this post Link to post Share on other sites
Fine wine, Belgian chocs. 1 Posted September 23, 2015 I hate the silicone instant gasket stuff that gets everywhere but I must admit to being a big fan of 'Wellseal'. http://www.wellseal.co.uk/ I rebuilt my VR6 engine earlier this year and put a smear of this on every joint (except the head gasket) and there is not drip or dribble anywhere. More importantly than any of this is of course is the fact that Wellseal smells ace. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 23, 2015 Use the rubber gasket. Victor reinz is a good make. Am sure I've had Victor reinz stuff from the dealer. Wouldn't use any sealant. Shouldn't need it. Can't remember the torque. Not much. Also two types of bolts. The later bolts are longer. I ended up buying a set of bolts as mine were mismatched. Quote Share this post Link to post Share on other sites
Fine wine, Belgian chocs. 1 Posted September 24, 2015 Torque setting for the bolts is 15nm/11lbft. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted September 24, 2015 Fine wine, Belgian chocs. said: Torque setting for the bolts is 15nm/11lbft. cheers any sequence to tighten up. Quote Share this post Link to post Share on other sites
Fine wine, Belgian chocs. 1 Posted September 24, 2015 I read somewhere about starting at the middle and working outwards. It seemed to make sense to me so that's what I did. I really can't imagine it being critical. I think the main thing is not to over tighten the bolts. If you do then there's the chance of deforming the flange on the sump or stripping the threads at the clutch side (as they screw into alloy). I used new bolts and squirted some brake cleaner into each bolt hole to make sure they were free of oil. Any lubrication in the threads will give a false reading on the torque wrench (it takes less torque to turn an oiled bolt obviously). This all sounds daft and over the top for bolting up a sump but I really didn't want it leaking. Quote Share this post Link to post Share on other sites
