Gavin A
Iso connectors
Hi,needing some help with which ISO connector i need to fit an aftermarket stereo to my 1994 vr6 . Any info would be much appreciated.
Thanks
Gavin.
Thanks
Gavin.
http://www.ebay.co.uk/itm/16-Pin-Male-ISO-Terminal-Block-Socket-Connector-Repair-Kit-/251161675325?hash=item3a7a67063d
These are the standard loom end connectors.... Which should connect into your stereo loom....
Modern stereo you will need to swap the yellow and red leads.
