RFvr6
central locking and window switches died
just as it says in the title, I done about 150 miles on sunday, windows sliding up and down all day long, central locking pump doing its job, I realise later on at night that the drivers or passengers side window switches arnt moving the windows, no noise from the motors or anything (the light in the switch is still lighting up so they are obviously getting power) then later on I find the central locking isn't working when I move the actuator in the drivers door
anything simple like a fuse? I have tested most of the fuses and they seem fine, anyone had this problem before?
Behind the drivers side rear door card is the control unit for those very things......fairly sure that's what it does anyway......No doubt someone with the definitive answer will be along soon :)
There's a separate fuse for the window/door module above the relays in a single fuse holder. 20A yellow. Lighting circuit is separate. If it keeps blowing you probably have a short circuit.
