2motion 10 Posted October 14, 2015 Hi there! I've recently brought a corrado :). Whilst being absolutely in love with the thing. I'm currently freezing my nadgers off. You guessed it, the heaters don't work. I've replaced the fan/motor with a new unit and changed the thermo fuse. Still no joy. Any ideas? Thanks in advance! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted October 14, 2015 So the heaters dont work on 1,2,3 and 4? Quote Share this post Link to post Share on other sites
2motion 10 Posted October 14, 2015 Nothing at all mate Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted October 14, 2015 does your heater blower fan work at all? even with a non working blower motor you should still be getting warm air when the heater dial is set to warm - unless your matrix has gone & then you will only get cold air even if dial set to warm if you have no response out of the blower motor it could be a blown fuse maybe - fuse board is under the drivers side footwell shelf did the seller mention anything about hot air feed? Quote Share this post Link to post Share on other sites
2motion 10 Posted October 14, 2015 Yes mate I am getting warm air through after a while driving it does get quite cosy . But I'm getting nothing at all from the fan. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted October 14, 2015 Yes mate I am getting warm air through after a while driving it does get quite cosy . But I'm getting nothing at all from the fan. ok that is a good sign - matrix is ok then :) have you re-checked the thermo fuse connections since you put the new blower motor in? could be the thermo fuse itself, the main fuse on the fuse board or possibly a break in the wiring going from heater speed dial to blower motor Quote Share this post Link to post Share on other sites
Dox 23 Posted October 14, 2015 If you put 12v to the fan does it run? Quote Share this post Link to post Share on other sites
2motion 10 Posted October 14, 2015 Not tried that yet. I'll recheck the thermo fuse and the fan. I've definitely got power to the plug for the resistor Quote Share this post Link to post Share on other sites
