ger040 3 Posted October 17, 2015 Whilst prepping my car for paint a small area of rust at the base of the front wing has now developed in to hole and I need a replacement wing my car is a g60 late 92 (oct) my chassis number is 50ZNK013089 is this a early or late spec wing that I need ? Thanks Quote Share this post Link to post Share on other sites
tomi 10 Posted October 17, 2015 N in VIN number mean is 1992 model , so You should have the late style wings , bumpers etc.. Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted October 18, 2015 My 92 g60 has late wings. Does the middle of the bonnet go up or down? Up is late down is early. Quote Share this post Link to post Share on other sites
ger040 3 Posted October 18, 2015 thanks for the reply I get a bit confused with the Corrado chassis numbers so I have a car with late wings but an earlier interior? just went onto classic parts and found that late wings are no longer available but early wings are? but got the shock at the cost. I wonder should I get it off the car and try to get it repaired I can't see any used ones being rust free - just had a look on eBay Quote Share this post Link to post Share on other sites
tomi 10 Posted October 18, 2015 ger040 said: thanks for the reply I get a bit confused with the Corrado chassis numbers so I have a car with late wings but an earlier interior? correct Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted October 18, 2015 Personally I would put up a wanted ad on here. I would get a used wing get that repaired then swap over and sell old wing. Quote Share this post Link to post Share on other sites
ger040 3 Posted October 19, 2015 SR_Neale said: Personally I would put up a wanted ad on here. I would get a used wing get that repaired then swap over and sell old wing. I live on the other side of the irish sea - will try locally first Quote Share this post Link to post Share on other sites
