MZpog 10 Posted October 26, 2015 Seems that its the season for intermittent ABS lights on my valver. I initially wondered if I'd disturbed a sensor when doing my coilovers, but having searched and read peoples symptoms I may be swaying towards the brake pedal sensor and wondered if they are the same on both valvers and VR's with the part number 357-927-810. Any input on my symptoms would be appreciated:- Along with the sometimes on/off ABS light at start up, it occasionally comes on/off with speed bumps. I also sometimes get a strange pedal with a vibration. When it does this the pedal isn't as hard, drops further and make the vibrating or grating noise. The car still stops but needs more effort, but I obviously want to sort this. Generally the light stays off but no doubt this will worsen if something is failing. Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted October 26, 2015 Have you had a code read done? Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 26, 2015 Have you had a code read done? I borrowed a code reader and checked a couple of times previously but note found. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 13 Posted October 26, 2015 IIRC you can test the brake pedal position sensor by holding down the brake pedal as you turn the ignition on if it is working properly you should feel a short pulse in your foot through the pedal Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 26, 2015 IIRC you can test the brake pedal position sensor by holding down the brake pedal as you turn the ignition on if it is working properly you should feel a short pulse in your foot through the pedal Will try this at lunch time. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 13 Posted October 26, 2015 Will try this at lunch time. fingers crossed for you fella Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 26, 2015 IIRC you can test the brake pedal position sensor by holding down the brake pedal as you turn the ignition on if it is working properly you should feel a short pulse in your foot through the pedal Didn't feel a pulse on the my attempts. First 3 of so were the same - put my foot on the brake (hard pedal), turned ignition on, pedal goes soft and moves a bit until hard again, started car and ABS light on. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 13 Posted October 26, 2015 Didn't feel a pulse on the my attempts. First 3 of so were the same - put my foot on the brake (hard pedal), turned ignition on, pedal goes soft and moves a bit until hard again, started car and ABS light on. hmmm I am fairly sure it is quite a distinct pulse but I will go check now for you as im in the VR today (valver hasn't got ABS thank fook lol) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 13 Posted October 26, 2015 hmmm I am fairly sure it is quite a distinct pulse but I will go check now for you as im in the VR today (valver hasn't got ABS thank fook lol) blimey cold out there ok so, in my VR, hold the break pedal down, put key in ignition, turn key to on (but don't start car) & as the key turns feel a clunk / doing under foot & is slightly audible Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted October 26, 2015 Seems that its the season for intermittent ABS lights on my valver. I initially wondered if I'd disturbed a sensor when doing my coilovers, but having searched and read peoples symptoms I may be swaying towards the brake pedal sensor and wondered if they are the same on both valvers and VR's with the part number 357-927-810. Any input on my symptoms would be appreciated:- Along with the sometimes on/off ABS light at start up, it occasionally comes on/off with speed bumps. I also sometimes get a strange pedal with a vibration. When it does this the pedal isn't as hard, drops further and make the vibrating or grating noise. The car still stops but needs more effort, but I obviously want to sort this. Generally the light stays off but no doubt this will worsen if something is failing. This is from Vagcat, appears the same for all RHD cars: http://www.vagcat.com/epc/cat/vw/COR/1992/76/54/846188/ Ian. Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 26, 2015 This is from Vagcat, appears the same for all RHD cars: http://www.vagcat.com/epc/cat/vw/COR/1992/76/54/846188/ Ian. Thanks Ian, your link suggests I have to be logged in to see stuff but I guess it's saying they use the same part (if it turns out to be the position sensor) Quote Share this post Link to post Share on other sites
Dox 22 Posted October 26, 2015 The pedal sensor is also fitted to MK3 Golf gtis etc the early type with square side repeaters (M plate and older). The ABS should scan, but some scanners can't connect with 20 year old technology. Look on ebay for someone local to you who scans with VCDS for a tenner or so http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=vcds+scan&_sop=7 http://www.ebay.co.uk/sch/i.html?_odkw=vcds+scan&_sop=7&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xvagcom+scan.TRS0&_nkw=vagcom+scan&_sacat=0 Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 26, 2015 (edited) Whilst looking for a VW specific thread for instructions regarding the fixing of the brake pedal position sensor, I did find this one regarding a Volvo item that looks similar. http://www.volvoforums.org.uk/showthread.php?t=97192&page=5 Edited October 26, 2015 by MZpog Quote Share this post Link to post Share on other sites
Jim 1 Posted October 26, 2015 I know DG Autotech were able to repair these, so that guide on the Volvo forum looks pretty plausible. Has to be worth a go! Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 27, 2015 So last night I scan again for ABS faults - no codes. Also scanned for engine codes which valvers shouldn't be able to read and got a code 00527 that I've cleared before. Cleared it last night and this mornings drive has been free from ABS light. Hmmm. Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted October 27, 2015 Well my scanner will scan the ABS and brings back the codes but when I try to clear the codes .... No can do.... Any ideas why Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 28, 2015 Well my scanner will scan the ABS and brings back the codes but when I try to clear the codes .... No can do.... Any ideas why None at all. The scanner I've borrowed lets me clear codes, just doesn't find any on the ABS system, which incidentally has behaved again. Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted October 28, 2015 What scanner did you have I got a VS450 which although stated as OBD2 I was assured it worked on a Corrado VR6 - whilst it reads the ABS codes in wont read the engine and it wont clear codes - have a I bought wrong one or have I got a faulty one. Thanks Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 28, 2015 What scanner did you have I got a VS450 which although stated as OBD2 I was assured it worked on a Corrado VR6 - whilst it reads the ABS codes in wont read the engine and it wont clear codes - have a I bought wrong one or have I got a faulty one. Thanks Dunno. It's an orange Ebay special that I borrowed from Wayne, so no doubt they'll be a picture on here somewhere. Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted October 28, 2015 Dunno. It's an orange Ebay special that I borrowed from Wayne, so no doubt they'll be a picture on here somewhere. Is there a make and model number on it? Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 28, 2015 Is there a make and model number on it? it's one of these http://www.ebay.co.uk/itm/Universal-OBD2-CAN-Bus-Fault-Engine-Fault-Code-Diagnostic-Scanner-Reader-U480-/131638726293?hash=item1ea6478e95:g:hz4AAOSwBahVZFfZ Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted October 28, 2015 Cool - now that's cheap - worth another punt and hope this one works - cheers Quote Share this post Link to post Share on other sites
AngusL 10 Posted October 28, 2015 Guys I have a 1995 VR6 and it talks nicely to the vag com via a USB PC lead and gave me the definitive error code that said bps sensor failure. The info is in here somewhere as I am sure I posted some pics of the innards of the brake position sensor that gave me the same grief with ABS lights and non functioning ABS. You can take out the BPS and fix it yourself if you can wield a soldering iron. It's basically a no cost fix there are a few solder joints that break inside the BPS and break and that's it game over ABS. There is a circlip that's fiddly to remove. Hint use a phone and video the underneath then look at the footage to see how the clip sits in a thin Channel holding the bps in place. A thin screwdriver in the right place gets it off. If this is your problem it's easier to fix than you think. Mines been working happily for just under a year now. Good luck Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted October 29, 2015 it's one of these http://www.ebay.co.uk/itm/Universal-OBD2-CAN-Bus-Fault-Engine-Fault-Code-Diagnostic-Scanner-Reader-U480-/131638726293?hash=item1ea6478e95:g:hz4AAOSwBahVZFfZ Did you say you could not read ABS codes with this or can you? - its these I need to read and clear - thanks Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 29, 2015 Did you say you could not read ABS codes with this or can you? - its these I need to read and clear - thanks Seems to read them on the valver but has never found any so I can't confirm. Wayne used it with success on his VR6 I believe. Quote Share this post Link to post Share on other sites
