Alty
G60 Throttle body help....
With the engine coming out very soon for rebuild just ruuning over a couple of things but this one has me stuck! This is the best image i could find to help me... The outlet that is sticking into his palm has boost/pressure pushing out but it's just going to the atmosphere ? googled as much as i could to find out what this is and where it should be going but no luck!
Any help appreciated
Thanks Scott
[ATTACH=CONFIG]82672[/ATTACH]
Edited by Alty
Ah, does it look like a brass fitting about 1cm diameter where a hose should go? If so I think its part the pipework for the carbon canister. Most g60s have now had this removed. If yours has then put a hose over it with a bolt in the end to just seal it off.
