robrado974 1 Posted December 28, 2015 Ive had an arm for the wiper motor for ages , its been powder coated , so i have one more day off before going back in to hell , sorry i meant work, so i decided to fit the new part. I took it off and all apart fine , apart from the spline part. It has to metal pegs like rivets that hold it on to the bar . The only way of getting it apart is to break the rivet part . Then your left with a set of splines that you cannot atatch to the bar anymore . Has anyone fitted a new bar , how did you fit the spines back on ?. Maybe they can be drilled to leave a hole and have rivets put through them or a nut and bolt . Help is much appreciated thank you . Rob Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 30, 2015 Bummer , bought some bolts today and they are snagging on the movement of the arm . I need to try and get some shorter threads and smaller heads . Quote Share this post Link to post Share on other sites
