Mk3highline
Obd2 vr6 won't start
I know it's a mk3 but it's basically same running gear
Hi I've taken the vr off the road but I went to start it other week and it failed to start
It had been stood for a few weeks
Thought it was fuel so with fresh fuel no joy
There is only spark on first turn of key just once
The fuel pump relay isn't clicking on there is no power going to it, I have tested the relay and it is working
I've also put direct power to the pump still no joy
Fitted a new crank sensor still no joy
There is power to the coil pack
The throttle body dose buzz with ignition on
I have a new if ion switch to fit in the next few days
Any help would be appreciated
Zak
