ryan_welshman 10 Posted January 25, 2016 Hey all Ok, so got a 92 rado with early interior. The direction for the blower seems to always be on the front facing vents whether i put it on windscreen or any other direction Also when the blowers are on the windscreen, its a stronger blow when its on the cold setting rather than hot, and blows more so on the driver side than passenger. So... anybody got any ideas if its broken cables or the direction box is too old ...? And also if i need to investigate the heater box, can you gain access by removing the centre console, or do i have to remove the whole dashboard?? I use my car daily and dont have a garage so would prefer not to have to rip it all apart to fix the issue Many thanks Quote Share this post Link to post Share on other sites
dragon green 5 Posted January 25, 2016 If you take out the centre consul you have access to the hot and cold flap, take the drivers shelf out,and you can just about get to the feet/window flap,it sounds like the heater box needs attention, Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted February 2, 2016 Cheers. Will have a go :-) Quote Share this post Link to post Share on other sites
