massbad69
What size spacers please ?
Hi
Wee question for you.
I'm keeping my Speedlines with the standard tyres on my VR6 with lowered Bilstein B12 kit on it.
What width spacers can I use front and rear to create a better look ?
I've got 10s on the front and 20s on the rear of my daily mk7 GTD but I'm unsure re the Corrado.
Thanks folks.
Swap em onto the corrado and see what you think. I think 10-15mm will be the limit though without scrubbing on standard et43 wheel, with 10mm spacers bringing it to effectively et33. My RXs are et35 and are perfect imo, so 10mm should be good.
Thanks for that.
I was going to try the 5 X 112 spacers with a bolt holding them just to get a look and I didn't think I would be able to use more than 10s.
You bring up a very good point (PCD) and one which I had overlooked! :lol:
Lol
I'm sure I will be able to get a good enough idea with it on with 1 bolt and hold it on the jack.
Usually I would have went for s bigger wheel with no spacers but fancied refurbing the spare Speedlines grey with diamond cut rim.
