northG60
Early interior dash bulb replacement
Hi all
Does anyone have a line on where i can source a new early dash bulb? as you can see in the picture its a complete unit with a two pin at the back ?
(one that sits behind the early heater controls)
pic attached
if there is a LED option to brighten it up over the tiny candle that sits there ? may be nice?
cheers
Stewart
I bought some 3mm led which were pre-wired with resistor and 20cm lead, not wired up yet but obviously if an original lamp can be sourced,would be alot better. Same with the cigarette lighter lamp
yeah I think ill either have to do that or try to buy a new golf mk2 heater face and steal the little bulb I seem to remember a friend did that.
bloody annoying this tiny little bulb
Not thought of the mk2 using same lamp. Worth investigating at local scrappy!!
