p0l1wrath 10 Posted February 22, 2016 Has anyone used any creation motorsport silicone hoses before? I'm looking at this set http://www.ebay.co.uk/itm/VW-CORRADO-GOLF-MK3-2-8-VR6-7-PIECE-SILICONE-RADIATOR-COOLANT-HOSE-KIT-H0169-/151848816187?var=&hash=item235ae50e3b:m:mA5ERq9eCvMhtSWAEkkNRlw and just wanted to know if anyone knew what the quality was like? or wether anyone has used anything from them before? Thanks Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 22, 2016 I know roose motorsport are very very good quality if that helps? Quote Share this post Link to post Share on other sites
odub 0 Posted February 22, 2016 I've got a mixture of hoses on my daily 225 TT. Some are Forge, SFS and Creations. All are good quality. Only thing is the Creations Motorsport pipes were much cheaper. I'd give them a look Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted February 25, 2016 Think I'll be buying this full set on Friday, will update people with pictures and thoughts when received Quote Share this post Link to post Share on other sites
Jim 2 Posted February 25, 2016 Please do - I'm thinking I'll be needing a full set of hoses very soon, so could be tempted to pick up a set at that price. Roose are twice the price, though I know they are well regarded so.. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted February 25, 2016 I have a set of roose on my VR, no issues with them & Vince at Stealth was very impressed with their quality when he fitted them EDIT: one piece of advice I would recommend based on my personal experience would be to NOT order the jubilee clips & use the standard VW constant pressure clips. Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted February 25, 2016 Have spoke with the seller, and they say the quality difference between the bigger brands is unnoticeable, but then I wouldn't really expect them to say any different... Quote Share this post Link to post Share on other sites
Jim 2 Posted February 25, 2016 Has anyone installed the full set of creation hoses? Just aware that often with these aftermarket kits there can be fitment issues - I know the Roose hoses were developed off an actual set of original VR hoses (I think supplied by Stonejag?) and of course bought / installed by quite a few forum members at the time so we know they're good.. don't want to get to a point of installing these to find they don't fit correctly. Reading around on various other VW forums, they seem to be held in pretty high regard. Just a bit of an known in Corrado land it seems? Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted February 25, 2016 Looks like they are based in Birmingham Jim, worth a visit to put your mind at rest? Ian. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 25, 2016 I have a set of roose on my VR, no issues with them & Vince at Stealth was very impressed with their quality when he fitted them EDIT: one piece of advice I would recommend based on my personal experience would be to NOT order the jubilee clips & use the standard VW constant pressure clips. Did you have problems with the jubilees that came with the roose hoses? Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted February 26, 2016 I have bought a set of hoses today, but won't be able to fit them for maybe two weeks, although will post some pictures of them when they arrive Quote Share this post Link to post Share on other sites
Jim 2 Posted March 4, 2016 I'm interested to know which hoses are missing from this kit? Their advert says it's a 7 hose kit, but the Roose Motorsport kit is a 9 hose kit? Leaning towards the Roose Kit - it is double the price, but does come with a lifetime warranty.. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted March 4, 2016 Did you have problems with the jubilees that came with the roose hoses? hi Jon sorry - only just seen this only with the one for the hose that attaches to the PCV valve - but this is more due to there not being much hoses prior to the 90 degree bend in said hose the OEM is in fact a one time use clip which is compressed /squeezed onto the hose - they are the round ones with the small castle turret kind of shape all others were ok & still are after about 18 months if I think back I believe I chose to use the roose jubilee's as I was worried using the VW constant tension ones might invalidate the roose warranty - might be worth speaking to roose to ask them about that point Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted March 4, 2016 I'm interested to know which hoses are missing from this kit? Their advert says it's a 7 hose kit, but the Roose Motorsport kit is a 9 hose kit? Leaning towards the Roose Kit - it is double the price, but does come with a lifetime warranty.. hi jim from comparing the 2 pictures it looks like it is the 2 small hoses I have circled in the image below - just in case....the red ones are the roose hoses ;) I think one of them is the hoses which is near the oil cooler at the front of the VR engine but cant think of hand where the other goes also - if on the roose picture you compare the large hose with the thinner section coming out of it & has a T junction. this is the hose which has the header tank over flow. on the other hoses the thinner over flow section is not manufactured into the thicker hose as per on the roose ones (where circled) although that doesn't have a T junction piece in it & is formed together finally - I chose roose due to reading about many many failures of samco hoses, which are meant to be extremely reputable. just a quick look on here & I think I found a handful of samco failure reports. as such I thought a lifetime warranty would be an advantage as if the so called market leaders suffer failures then it doesn't potentially bode well for cheaper versions finally, again from memory, I am sure I read a fair few things about the quality of the internal hoses surface. such that the samco's often have a uneven internal surface, which could then have an effect on the coolant flow rate. all of the roose hoses that I received had very smooth internal walls & I think I remember Vince being complimentary about such Quote Share this post Link to post Share on other sites
Jim 2 Posted March 4, 2016 Good information mate - appreciated. Think I'll bite the bullet and order the Roose ones, possibly with their clips as well. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted March 4, 2016 Good information mate - appreciated. Think I'll bite the bullet and order the Roose ones, possibly with their clips as well. I was & am really pleased with mine fella :D you will definitely need the OEM clip for the hose which goes onto the PCV valve but if you are getting stealth to fit them I would imagine Vince will recall what he did with mine. if not mention "Andy, blackberry VR, head rebuilt twice, polished inlet mani" ;) & that should jog his memory as we spent quite a lot of time together. or say 'the guy whose brought his white valver back after Jon found it on ebay' lol I would give them a ring & ask if you can use the OE constant tension clips too m8 or if they insist using their jubilee's for their warranty Quote Share this post Link to post Share on other sites
Jim 2 Posted March 4, 2016 I was & am really pleased with mine fella :D you will definitely need the OEM clip for the hose which goes onto the PCV valve but if you are getting stealth to fit them I would imagine Vince will recall what he did with mine. if not mention "Andy, blackberry VR, head rebuilt twice, polished inlet mani" ;) & that should jog his memory as we spent quite a lot of time together. or say 'the guy whose brought his white valver back after Jon found it on ebay' lol I would give them a ring & ask if you can use the OE constant tension clips too m8 or if they insist using their jubilee's for their warranty I can do, but to be honest all my clips and stuff are looking tired / corroded so would be a good time to replace them all really. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted March 4, 2016 I can do, but to be honest all my clips and stuff are looking tired / corroded so would be a good time to replace them all really. kind of my point Jim - you might be better buying new OE clips rather than the jubilee's - though that could work out more costly of course Quote Share this post Link to post Share on other sites
Jim 2 Posted March 4, 2016 Yeah - plus a load of ballache going through ETKA identifying all the hoses, and the clips that I'd need to buy, the possibility of some of them being obsolete and on back order, etc...... Hmmm..... Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted March 4, 2016 Yeah - plus a load of ballache going through ETKA identifying all the hoses, and the clips that I'd need to buy, the possibility of some of them being obsolete and on back order, etc...... Hmmm..... ahhh but the excellent helpful resource of Thursdave on here could save you all that trouble very quickly - a PM later & he could probably whip up all the info from his VW system he very kindly sent me an exploded diagram of a headlight so as to help me when I try to transpose the adjusters from one set to another or inspect your current ones & only replace those that look past their best maybe Quote Share this post Link to post Share on other sites
Jim 2 Posted March 4, 2016 Well I have er.. access to ETKA so getting all that information isn't the problem per se... it's just then going to the dealer, reeling off the list of parts, etc etc etc, being told something is on back order, etc etc... vs just clicking the option that says 'include the clips' on the order for the hoses :) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted March 4, 2016 Well I have er.. access to ETKA so getting all that information isn't the problem per se... it's just then going to the dealer, reeling off the list of parts, etc etc etc, being told something is on back order, etc etc... vs just clicking the option that says 'include the clips' on the order for the hoses :) ha ha ha I have to admit I completely agree with that final sentiment Jim lol working in IT I very much like to save 'clicks' anywhere I can Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted March 8, 2016 Apologies for not mentioning anything, but have been real busy, received the kit, showed it to a few friends and we're all happy with the quality of the hoses, can also confirm its the two oil cooler hoses which are missing from the set, but having a mocal oil cooler rad setup I wasn't too fussed about having these two hoses, haven't fitted them yet, or even offered them up to the standard set to check for fit net issues yet, but should have flushed the system and fitted the kit by the end of this weekend, at which point I can report back on any fitment issues Quote Share this post Link to post Share on other sites
Jim 2 Posted March 8, 2016 Cool - thanks for the update :) Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted March 8, 2016 Did you have problems with the jubilees that came with the roose hoses? Someone posted on here a while back about not using the jubilee ones but a different type - think I t was spring clips Quote Share this post Link to post Share on other sites
