blackrs2000custom 10 Posted March 15, 2016 I'm going to fit new rear beam bushes . Dropping the beam out but how hard is it to pull the new bushes through the hole ? Cheers Neil Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted March 15, 2016 blackrs2000custom said: I'm going to fit new rear beam bushes . Dropping the beam out but how hard is it to pull the new bushes through the hole ? Cheers Neil hi Neil I believe to remove & refit the bushes you will need a press & can not be done by hand, or is extremely difficult from personal experience I would recommend preparing to replace the brake bias valve as they can be very troublesome to disconnect so as to allow the rear beam to drop ok also, avoid poly bushes etc for the rear beam & use the standard OE bushes as they are designed to flex somewhat Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 15, 2016 I borrowed a sealey bush tool from someone on here, made the job quite easy really. He had modified it a little, but its basically a thread bar with some bits on it you wind up. Quote Share this post Link to post Share on other sites
blackrs2000custom 10 Posted March 15, 2016 Got a threaded bar and various end for it just wondering how tight it is to pull through Quote Share this post Link to post Share on other sites
swiftkid 1 Posted March 15, 2016 I think you have to pretension it as well when you put it back on, something I'll need to check when I do mine in the not too distant future. BTW, your username "blackrs2000custom"... MK2 escort? if so, pics please! Quote Share this post Link to post Share on other sites
blackrs2000custom 10 Posted March 15, 2016 swiftkid said: I think you have to pretension it as well when you put it back on, something I'll need to check when I do mine in the not too distant future. BTW, your username "blackrs2000custom"... MK2 escort? if so, pics please! Hope you like Quote Share this post Link to post Share on other sites
STU175 0 Posted March 15, 2016 i had to renew brakelines when i done mine. they wouldnt come out of compensator Quote Share this post Link to post Share on other sites
swiftkid 1 Posted March 15, 2016 Oosh, that is absolutely beautiful! So very jealous. Would love one, if I ever got rid of the corrado that is what I'd want Quote Share this post Link to post Share on other sites
