blair321
aktiv speaker system
hi guys
ive just bought a new headunit for my US spec g60, because of the aktiv system i cant plug it in. is there an adapter or am i talking about rewiring the whole system,
cheers
Just don't connect the blue/white (IIRC) wire that is for the auto sound level function.. would have thought that power and speaker cables would be as normal?
speaker cables are different. theres less speaker wires than there needs to be. i was told that with an aktiv systerm the speakers run off an amp????????????????????
IIRC there are built in amps behinds the speakers in the doors. Fairly basic looking on a circuit card. When I tried to get my Pioneer fitted in my 1st Corrado VAG said they couldn't do it. They were fitting blaupunkt gamma radios as standard to control/run the system. In fact they were so helpful I ended up going to a local ICE specialist and getting them to fit it. I found out afterwards that it only needed two speaker connections not four as I first thought
The rest of the system has active amps/crossovers I think.
