will 2
drain holes
are there any water drain holes around the scuttle area as my drivers side footwell is soaking and the car has been standing for quite a while . never had any water leaks when it was in use
Is the car parked flat ?
There's not much to leak in that area,BUT mine did leak around the throttle cable grommet
mine had some corrosion around the windscreen which was letting water through and into the footwell. other than that, have you checked the sunroof drains?
to be honest since I repaired the sunroof. I have only opened it once in about 5 years and that was yesterday, to see if it was still working , but good point I will check them out even though I made sure they were clear when I done the roof
