will 2 0 Posted April 14, 2016 are there any water drain holes around the scuttle area as my drivers side footwell is soaking and the car has been standing for quite a while . never had any water leaks when it was in use Quote Share this post Link to post Share on other sites
dragon green 6 Posted April 14, 2016 Is the car parked flat ? There's not much to leak in that area,BUT mine did leak around the throttle cable grommet Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
will 2 0 Posted April 14, 2016 no its up at the back on axle stands but not that high Quote Share this post Link to post Share on other sites
Philuk 0 Posted April 15, 2016 mine had some corrosion around the windscreen which was letting water through and into the footwell. other than that, have you checked the sunroof drains? Quote Share this post Link to post Share on other sites
will 2 0 Posted April 15, 2016 to be honest since I repaired the sunroof. I have only opened it once in about 5 years and that was yesterday, to see if it was still working , but good point I will check them out even though I made sure they were clear when I done the roof Quote Share this post Link to post Share on other sites
