will 2
sill photo
can any one post up a pic of the rear end of the sill as I need to see the profile before I start fabricating some metal
thanks
i had a similar problem i cut out the rusty bit
[ATTACH=CONFIG]83653[/ATTACH]
then got some steel and put a 90 bend to form the lip then bashed with hammer on a sand bag to get the shape right using the part ide cut out as a template.
not easy but doable
[ATTACH=CONFIG]83655[/ATTACH]
[ATTACH=CONFIG]83654[/ATTACH]
[ATTACH=CONFIG]83656[/ATTACH]
hope this helps mate!
oh also i filled the lip with under seal slightly higher on one side to stop the water sitting there and rusting it again. it should drain out nicely now
Edited by STU175
