will 2 0 Posted April 18, 2016 can any one post up a pic of the rear end of the sill as I need to see the profile before I start fabricating some metal thanks Quote Share this post Link to post Share on other sites
Cressa 46 Posted April 19, 2016 don't know if that helps Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
STU175 0 Posted April 19, 2016 (edited) i had a similar problem i cut out the rusty bit [ATTACH=CONFIG]83653[/ATTACH] then got some steel and put a 90 bend to form the lip then bashed with hammer on a sand bag to get the shape right using the part ide cut out as a template. not easy but doable [ATTACH=CONFIG]83655[/ATTACH] [ATTACH=CONFIG]83654[/ATTACH] [ATTACH=CONFIG]83656[/ATTACH] hope this helps mate! oh also i filled the lip with under seal slightly higher on one side to stop the water sitting there and rusting it again. it should drain out nicely now Edited April 19, 2016 by STU175 Quote Share this post Link to post Share on other sites
will 2 0 Posted April 19, 2016 thanks also :) Quote Share this post Link to post Share on other sites
