stuarttaylor37 13 Posted May 21, 2016 (edited) I have an electrical problem 10A fuse for dash lights display keeps fusing every time I replace it, headlights work on the switch.(Switch is an updated version.) If I remove the bulb holder for the heater dials and replace the fuse everything is fine,as soon as I put it back in either with or without the bulb the fuse goes again. I replaced that bulb last week with a new one as the old one was really dim. I can't see any shorts within the bulb holder itself, any ideas on what to look for or how to trace the problem please? Thanks for reading Edited May 21, 2016 by stuarttaylor37 Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted May 22, 2016 Anyone? Quote Share this post Link to post Share on other sites
Cressa 45 Posted May 25, 2016 You're going to have to test from the bulb point onwards with a continuity tester. Check positive to negative to ensure there is nothing short circuited. Is the wiring free with no crazy fixing screw into anything. Probably telling you what you've already checked! !! Can you get a wiring diagram for this circuit and is everything else working. If so its looking definitely like a fault at this unit. .. good luck Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
