Mal77 0 Posted July 6, 2004 My mates got it on a 93 L, We had scanned thru VAG COM and it came up with Lamda sensor out and Knock Sensor out, I got the knock sensor Part Number W054 905 377A, but problem is now where is it located, any help guys? Mal Quote Share this post Link to post Share on other sites
Henny 0 Posted July 6, 2004 Knock sensor is normally on the front of the block with a 13mm headed bolt going through the center of it to the left of the dip-stick tube... 8) Quote Share this post Link to post Share on other sites
kongo127 0 Posted July 6, 2004 And don´t forget the right torque for it! :idea: About 15lbs i think... :? Quote Share this post Link to post Share on other sites
Henny 0 Posted July 6, 2004 yup, between 15 and 17 LbFt... 8) Quote Share this post Link to post Share on other sites
Mal77 0 Posted July 9, 2004 so its kinda straight forward then? how long if nothing is seized would it take> Quote Share this post Link to post Share on other sites
Henny 0 Posted July 9, 2004 knock sensor should take 20 mins tops... Lambda's a bit more of a git 'cos it's on the top of the cat so can be a real sod to get at... :| Dunno how long to do one, as I've never had to do one with the car in one piece 'cos I changed mine when the engine was out... ;) 8) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 9, 2004 16Vs won't talk to VAG-COM? What protocol did you use? Quote Share this post Link to post Share on other sites
