Grrrrallye 0 Posted July 12, 2016 Evening all, I am in the process of putting the VR back together. The problem I have is that the thing has been in bits that long the door rubbers have lost there shape. If some one could tell me where the rubbers meet it would be a massive help to put everything back together. I'm talking about the seal that goes right around the inside of the door frame and the door closes against. Thanks in advance Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 12, 2016 It joins right in the middle at the bottom. There should be a small metal piece that slots in and connects them together, but it's usually rotted out. I used a thin piece of aluminium to stop it happening again. Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted July 13, 2016 Brilliant, thanks for this, I can have a go at this tonight Quote Share this post Link to post Share on other sites
will 2 0 Posted July 14, 2016 any photos of where this metal pipe fits in the rubber Quote Share this post Link to post Share on other sites
jekel 10 Posted July 18, 2016 I've just fitted new driver side and kept passenger side on for reference, the join should be exactly level with the rear most part of the door pocket/holder (thing you keep your sunglasses in etc, whatever it's called). Quote Share this post Link to post Share on other sites
will 2 0 Posted July 18, 2016 my join is on the bottom in the middle, so which is the correct place for the join Quote Share this post Link to post Share on other sites
