16vStyle
Genuine 16" BBS RS - 4x100 ET24 - 7" wide. Just been built!
Hi,
I’m selling my set of genuine 16” BBS RS – 7” Wide – ET24 – 4x100.
Absolutely perfect fit for all 4 stud Golfs and Corrados etc.
Have just been built up and sealed this week after having the Mike the Polisher treatment. All work -Polishing and Powder Coating carried out only a few weeks ago.
(Started off life as a mint set of BBS RS035 5x114.3 16x7.0 ET+24 which had come over from Japan)
All 4 wheels are identical and are made up of:
5.5" Inners and 1" outer lips all round (polished).
Centres – Professionally filled and re-drilled then lathed down so are completely smooth. Retained the alignment lugs for the waffle plates. Then I’ve had them powder coated in original BBS Silver by Mike the polisher a couple of weeks ago.
Waffle plates – All in perfect condition, powder coated a few weeks ago and all have the alignment tags intact
1” Outer lips – All original BBS and polished by Mike the Polisher a couple of weeks ago
Inner Barrels - completely original and in great condition
Nuts – Choice of either:
## Half height nuts – Absolutely pristine, Polished by Mike the polisher a few weeks ago.
## Full Height nuts – I bought them a while back as I prefer the full height. Polished, great condition.
(You’ll see both sets of nuts used in the pictures. Probably best to pick which ones you want on collection, and I’ll sell the other set.)
I’ve also got the 4 retaining clips so the waffle plate and nuts don’t fall apart every time you take them off.
Bolts – Brand new chrome bolts – all torqued up (with Loctite)
Will come with all the necessary extras to bolt straight up:
Spigot rings - 4 x 73mm > 57.1mm (for 4 stud VW etc)
Tuner Bolts x 16
BBS Spanner x 1
It’s the complete package and is all absolutely mint! I'm looking for £1600
Any questions please just ask, text or call – 07814 908 684
