hendrikbmx 0 Posted August 12, 2016 Hi, I am looking for the connector and maybe you have one that has a bad probe or no probe, all I need is connector with 10cm wires , bought the wrong one and I will match new sensor with old connector and solder it together. I need this square type of connector. , left on pic PM me if you have one, thanks. Hendrik Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 12, 2016 I maybe able to help, but why do you not simply return what you bought and get the correct one? They are easily available. I think I have a 93 VR6 one at home and will try to dig it out later this evening and have a look. Quote Share this post Link to post Share on other sites
hendrikbmx 0 Posted August 16, 2016 I bought it years ago and from another country so cannot return it. I am still looking for one. Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 16, 2016 Ok. Will take a look at the one I have tomorrow. I'm away at the minute. PM me your address just in case. Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 18, 2016 (edited) @hendrikbmx - I can sell you the whole original lambda sensor that I took off my VR at 90K miles (it was working fine at the time, simply a maintenance precaution), or I can remove the pins and give you the connector only if you want? As far as I know, these connectors should be readily available through a dealer by the way - I'll see if I can get the part number for you. The whole probe should be part#535906088 for a VR. EDIT - actually just checked your original post and photo - my sensor has the rounded connector on the right of your picture, so is probably no use to you - apologies. But you can definitely buy these through the VAG dealer, and they also sell cable/loom repair sections, which are essentially a length of wire with the pins already present at each end. Cheers. Edited August 18, 2016 by fendervg Quote Share this post Link to post Share on other sites
