cliveyp 0 Posted July 9, 2004 Where will i find, and how do i go about changing, the brake pedal position sensor on my 94 VR? I need to get this done before i can sell it, and i don't reckon it can be a hard job so i'll do it myself. That's the error that showed on the diagnostics when the light first came on anyway. Tends to be more on than off now. Quote Share this post Link to post Share on other sites
andycowuk 0 Posted July 9, 2004 i think it is bellow the master cylinder on the servo Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 9, 2004 Its an ATE part, about £50 from VW and is situated where Andy says... To change it pump the pedal to release the servo vaccum, unplug it then using a mirror you need to slide a small screwdriver underneath it to release the clip then it just pulls out... They come with some coloured bits of plastic that sit on the end so you should change like for like... Quote Share this post Link to post Share on other sites
