jaybo
More Parts Needed Again
Hi All,
I'm after another batch of bits if anyoen has them? I'm of on holiday on Thursday evening so ideally would like to fit before then.
As follows -
All x 3 speakers pod screws. (all same length?)
All x 4 speaker rubber mounts
Jason
Edited by jaybo
..also after the white clip that the door lock pin connects to. I snapped a secone one. :-( P/N - 357837083
Hi mate. Can you still supply these? I will buy the white clip new as they are brittle things.
Can anyone else match the rest?
Sent from my ONEPLUS A3003 using Tapatalk
Hi there pics of bits I have found one door mount.
Also which screws out the picture do you want for seat belt trim.
Also seems like a mix late door surrounds but the door mount seems from early car
Sent from my SM-G357FZ using Tapatalk
Cool. Need the door mount and two screws. Missing the screw from teh other door too.
Need to two scres that attach the rear seat belt mount.
Ah really? I thought they didnt line up? The car is an early one so the cards are late? Can i fit late handles on an ealry car? If so then it would make sense to fit the correct for each door?
hi mate yes you can fit the late to early but the indentation on teh door card wont look right. Its up to you if you want them to match. Take a pic of your other side and see if you have the right one one that side
Prefect matey! It was actually the door handle itslef (early type) i was after, not the surround. DO you have one of these?
If so then I will take the lot. How much posted? Paypal ok?
I don't suppose you have a workign fan heater resistor thingy too do you? I've only got full speed, no 1,2,3 on mine.
Awesome. Let me know how much posted and your PayPal. Can you get them to me for mid week next week?
I've read a few versions of this but found quite a few people have bought the diode to find the resistor was actually the bust part.
i thought that was the thermal resistor
MMost bits soted. Have updated the first post with what I still need. Any of you awesome people able to help? ;-)
